I can't load genesis into poser pro 2012
faisanfaisan Posts: 600
I can´t load the genesis figure into poser pro 2012, it has been installed, but when I try to load it into the scene a window appears and tells:
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Downloads\Runtime\libraries\Character\DAZ People\Genesis.py", line 1, in
import dson.dzdsonimporter
ImportError: No module named dson.dzdsonimporter
The files I installed:
14812_GenesisStarterEssentials_1.6_trx
14812_GenesisStarterEssentialsPoserCF_1.6_dpc
DSON_Importer_for_Poser_1.0.0.9_Win32
I hope someone can help me,
Thanks! :(
    Did you install the DSON plug in the main Poser runtime? Like all python scripts, they must be installed to the Python folder in the main Poser app folder.
    If you installed all three to an external runtime, Poser doesn't see it.
    If you don't have DS 4.5 installed, you must install the DS4x files as well. The DS Trx and Poser Companion files can be installed to an external runtime together.
    You need the latest SR (3.1) installed before you install the DSON.
  • fixmypcmikefixmypcmike Posts: 19,718
    GSE and GSE PoserCF should NOT be installed into Program Files if you are using Vista/Win7/Win8
  • faisanfaisan Posts: 600
    Then where must I install them?
    Into a runtime that's not in a protected folder -- the default for Poser8+ is in Documents
