making a morph universal
assmonkeyassmonkey Posts: 0
I moved over some morphs
The head morphs are fine, they can work on any gender, but the body...not so much
Like, the male superhero morph looks well on a female body, but the female counter parts don't (I'm talking about the muscle pack you can get for V4 & M4)
Can I make them universal?
They're good morphs, I just wish to use them for both genders. And wanting to keep both counter parts because of the size difference in the morphs.
Or would it just be easier to keep them set to a gender
Also, how do you pick between using a morph asset or shape asset?
I'm moving free Gen4 body and head morphs over for use (hand dialing them all) so other can use them.
  • Richard HaseltineRichard Haseltine Posts: 111,504
    Shape Asset? I see Shape Presets (which store the settings for the morphs, but not the morphs themselves) and Morph Assets (which store the morphs themselves.
  • KatteyKattey Posts: 2,899
    edited May 2013
    If you moved morphs from V4 and M4 you can "subtract" V4 shape off the morph with V4 Iconic for Genesis. After that just save obj and re-import into Genesis as more unisex morph. Or just use M4 variant.
    Post edited by Kattey on
  • assmonkeyassmonkey Posts: 0
    Can the V4 shape go below 0???
    What I did was, I exporting V4 with say...Amazon build, brought that morph in with Morph Pro, rigged V4, then used the transfer tool to move to clone that morph to Genesis, and I dialed the Amazon morphs to 100%
    Yes, you can unlock the limits of every morph and dial it anyway you way, -100%, +100%, +10000 even if you feel fancy and enjoy surreal imagery.
    If you used my tutorial, the V4 default morph should've been already negated but if you didn't, you can try to dial V4 Iconic Shape -100% and see if it works for your Amazon morph.
    No, I dind't put in the V4 or M4 shapes in before the morphs...but the boobs still come up anyway.
    While my female or male figure will look sexy either way if I dial in the Adonis morph, because it doesn't mess with the chest
    edited May 2013
    If you transferred morphs from original V4 figure, V4 default shape (which has boobs) will be embedded in all your morphs, while M4 transfer will give you a bit more unisex/masculine look. You need to "subtract" V4 shape via V4 Iconic Shape probably after transfer, to get rid of boobs.
    Meaning...going into the negative zone for V4 shape?
  • murgatroyd314murgatroyd314 Posts: 1,569
    The problem is simple. Any V4 morph which affects the breasts will continue to affect the breast area when transferred to Genesis, regardless of whether the underlying shape is male or female. Short of using a modeling program to adjust the morphs, I don't think there's a solution.
    I was dialing down the chest percent when fixing it from the morph loader, that seems to work a little
