full body morph question (just using the head)
assmonkeyassmonkey Posts: 0
How can I isolate it?
I"m trying to transfer morphs from Gen4 to Genesis and some are full body (body and head), but I want to transfer them over as Head and Body
  • Richard HaseltineRichard Haseltine Posts: 111,937
    If there are separate morphs on the original figure, you should - as far as I know - be able to transfer those individually, but you can't split a morph by body parts on Genesis - all you can do is use a modeller to make new morphs using only part of the original morph, and smooth the join, then load back with Morph Loader Pro.
  • assmonkeyassmonkey Posts: 0
    No, it's a FULL body morph...not 1 head morph and 1 body morph. I know how to use the transfer utility, I don't need a modeler to move an M4 morph onto Genesis. I just don't want it to be a full body morph
  • KatteyKattey Posts: 2,899
    What process do you use to transfer morphs?
    If you want to limit a full body morph to only certain body parts then you do need to use soem kind of external tool to help.
