What is this I never come across it before
in The Commons
What is this I never come across it before. Having loaded a torso texture and editing it to match the one on the char and saving it
into the same folder and the one the char is using I tried to load that new texture only to get
https://www.dropbox.com/s/ho4g8fj6hx53286/Screenshot 2017-12-07 13.52.53.png?dl=0
I don't get it. I have never had an issue changing a texture like this before
It does not load as you saved your new material in the connect folder - You need to save your material preset into your "normal" library (The place DIM installs to)
Thank you
Ok I don't rember but it's possible I have allways saved the char exported the mats then edited which would put the nats in a different folder maybe
