Changing default file location
William W_ Connors
I have a new computer with an SSD C-Drive. I need to tell Daz to use the D-Drive. I believe I have DIM doing that, but files I download from the products tab in DAZ go to the C-drive. Can someone point me at a way to change this?
Thanks!
If you want application in general to use the D: drive you should change the location of your Docuemnts folder (by finding it under C:\Users\YOU, right-clicking, selecting Properties, and using the Move button in the Location tab). That won't, however, affect already-installed applications. If DIM is using the correct paths now you can sync DS using this script http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start - just download it and then drag it into the viewport of DS.
