DIM Settings for Hexagon
Daywalker Designs
Just for general information, these are the settings I used for the Hexagon Beta
Download Filters:
Check Hexagon
Check 32 bit, since that's all that is available right now
Check Public Build
Check Windows, since the MacOS version if it exists may not work on newer versions of that OS.
Programs:
Create installation path for Public Build, as this option is not set by default yet.
These things should enable you to find the beta main download and install it. It must be installed before the content pack will install.
Installing the application should add the path under Applications, but note that if you download the content and the application in one go the content will complete, attempt to install, and error out before the application is done.
True. Richard, can you make this a sticky, as it should have useful information for folks.
