Comparision 3Delight vs. IRAY Render
Hi, my Name is Achim and I have DS 4.10 for some 6 weeks or so. in th Attachment,the left Pic was rendered in 3Delight and should have a certain dramatic effect.by the Spotlight
On the right the same Pic with IRAY, with exact the same light-settings. Seems, IAY ignores the Shadows aused by the Spot.
Or what I am doing wrong??
Thanks in advanve for your Comments
Cheers
Achim
800 x 455 - 98K
It looks like you have a second light source in the scene which is why you are not seeing the shadow. In the Render Settings on the Environment tab make sure Environment Mode it is set to Scene Only instead of the default Dome and Scene.
Also, check the "auto headlight" setting in the general render settings, I always set it to "Never".
