Morphs++ for V4
Hello? I tried to keep my questions all in one place, but I guess I don't know how anything works anymore... LOL
Anyway... How do I install Morphs ++ for V4? Letting the DIM "install" them doesn't work and the power loader doesn't show up anywhere either. I'm so confused. Please? Can anyone spare a few minutes to help me figure this out?
  • If everything is installed in the same location, the PowerLoader should be popping up when you load the figure.
  • I'm doing everything brand new. So... it should be putting everything in automatically, right? I can't figure out why I can't get it to work
  • V4 installs... but not her morphs and I can't find the powerloader
  • OK... NM. I uninstalled everything... Then just did V4 and her PowerLoader and then I installed Morphs ++ and it worked. Thanks for stopping in and answering me Agent.
  • Np problem. Glad she works now. :)
  • One more thing if you have a minute? I also am having a hard time installing and finding Generation X plugin. I install it, but can't find it. Documentation says I have to first register it by going into the about plugins tab, but it isn't listed. Any ideas what I'm doing wrong there?
  • You might have installed it in the wrong place. Mine shows up in Help>About Installed Plugins as Genesis Generation X.
  • Mine is not showing up there. I looked again and again. The DIM is installing it whereever it wants to. I have no idea why it isn't showing up, but I am wondering if its because the version I have has not been updated. I have Generation X, not Generation X2... Generation X is no longer in the store. But shouldn't I qualify for the update? Having already purchased?
    I'm not even sure that is the problem. Is there a way to find out?
  • In your DIM, check the Settings>Applications tab, and make sure your DS 4.5 path is pointing to your DAZStudio4 directory in your program files.
  • You should be able to install it to DS 4.5+, it is updated to that version.
  • Have you entered your serial number via Help>About Installed plug-ins, assuming that is how GenX works?
  • JasmineSkunkJasmineSkunk Posts: 1,906
    edited December 2017
    That is how the documentation says it should work, but when I look in Help>About Installed plug-ins, it is not listed.
    I suspect that the version of Generation X I have in my product library has not been updated, since I have "Generation X", and the version in the store is Generation X2.
    But, I'm thinking I need one of the Admins to put the lastest updated version in my product library.
    If that is not the trouble, I don't know what it could be.
    Post edited by JasmineSkunk on
  • That is how the documentation says it should work, but when I look in Help>About Installed plug-ins, it is not listed.
    That's not the trouble. I still have Genesis Generation X in my library, and it still shows in my plugins.
  • OK... So What could it be?
  • It says it installed it here:
    Application Data (C:/Users/Jasmine Skunk/AppData/Roaming) :
    /DAZ 3D/Studio4/GenX/about.gxd
    /DAZ 3D/Studio4/GenX/backup.gxd
    /DAZ 3D/Studio4/GenX/file.gxd
    /DAZ 3D/Studio4/GenX/folder.gxd
    /DAZ 3D/Studio4/GenX/gen4.gxm
    /DAZ 3D/Studio4/GenX/gen4.gxp
    /DAZ 3D/Studio4/GenX/gen4_2.gxp
    /DAZ 3D/Studio4/GenX/K4Clone.gxf
    /DAZ 3D/Studio4/GenX/K4Clone_2.gxf
    /DAZ 3D/Studio4/GenX/M4_CTRL_JawFix.dsf
    /DAZ 3D/Studio4/GenX/M4Clone.gxf
    /DAZ 3D/Studio4/GenX/M4Clone_2.gxf
    /DAZ 3D/Studio4/GenX/Michael4.gxf
    /DAZ 3D/Studio4/GenX/Michael4_2.gxf
    /DAZ 3D/Studio4/GenX/V4_CTRL_JawFix.dsf
    /DAZ 3D/Studio4/GenX/V4Clone.gxf
    /DAZ 3D/Studio4/GenX/V4Clone_2.gxf
    /DAZ 3D/Studio4/GenX/Victoria4.gxf
    /DAZ 3D/Studio4/GenX/Victoria4_2.gxf
    DAZ Studio 4.5 (64-bit) :
    /docs/Plugins/Genesis Generation X/Genesis Generation X.dsx
    /docs/Plugins/Genesis Generation X/GenX.pdf
    /plugins/d3dGenX.dll
    /plugins/initialize.dzime
  • agent unawaresagent unawares Posts: 3,513
    Okay. So my DAZ Studio 4.5 is in a DAZStudio4 folder, not Studio4. Where is your DS folder?
    Post edited by agent unawares on
  • I'm using the lastest version of Daz Studio 4.10 My DS folder is in C:/Program files/Daz3D/DazStudio4
  • But it installed it in my User folder, not in the main Daz Studio folder.
    Can you check in your DIM and see where Generation X is installed on your system?
  • Look in your DIM Settings>Applications. Change your DAZ Studio 4.5 path to "C:/Program files/Daz3D/DazStudio4"
  • It's okay that it put stuff in your users folder. It just sounds like the main plugin is going in the wrong spot. It should be "C:/Program files/Daz3D/DazStudio4/plugins/d3dGenX.dll"
  • it's not installing the .dll on my computer
  • Is DIM giving you an error? Does DIM say it's installed?
  • The DIM says it's installed to (C:/Users/Jasmine Skunk/AppData/Roaming) but the file d3dGenX.dll is not anywhere on my computer
  • OK... I uninstalled everything. Tried the manual instal instead of the DIM and it went in... Now to see if I can get it to work... Wish me luck!! Thank you so much Agent!! :)
  • Good luck!
  • Thank you! smiley
