Measure Metrics Script? (Solved)
evilded777
Did a major reinstall lately, and somehow seem to have lost the Measure Metrics scripts. I've installed the plugin and the content... poses and wearables but no scripts.
Wondering, also, if this is going to be updated for Genesis 8.
Post edited by evilded777 on
If I remember correctly, the scripts are under Utilities in the Content Library. And they have been updated to support Genesis 8.
They are updated for Genesis 8 as I have them & have used them on Genesis 8. I have DAZ Studio Public Beta 4.10.0.121 (64 bit). They are difficult to read which of the icons to click in 'Utilities' under smart content for MM/FM script for Genesis 8 though. They are in Content Library too.
The scripts are Figure Metrics, a PA set included with the plug-in.
Does that mean I don't get them as I am not a PA?
No, it simply means that the scripts were created by a PA, and DAZ chose to include them in the plugin package because they improved the usefulness of the plugin.
No, you will have them and all owners of the Measure Metrics product will have them. Figure Metrics come with the Measure Metrics product.
1st you apply the Measure Metrics preset & then you click the Figure Metrics preset, make your adjustmeents, save a MM/FM config file if you like, then apply a preset to remove all the MM sizing aid models from the model you are adjusted the measurements on.
Well, I don't have them.
No script for Figure Metrics, no cleaup script...
Bugger. I found it. Figure Metrics is it's own install, does not appear to be Connect enabled.
Although Figure Metrics isn't an actual plug-in it needs to be installed like one - I think part or all of the script goes in the application folder - which requires DIM running with elevated privileges ("Do you want to allow DIMHelper.exe to Make changes?") and can't be installed with Connect.
Where did you find it? Can you please help me?
