pwToon Video Renders: Flickering Figure Outline Problem
I did my first video render on DAZ Studio this evening, but I do have one problem.  How do I make the outline not flicker when moving the figure?
Here is a video to illustrate proof:
https://m.youtube.com/watch?feature=youtu.be&v=WtDNbzDCrek
  • EightiesIsEnoughEightiesIsEnough Posts: 1,271
    edited November 2017
    Just to clarify, you might likely see the problem if you expand the screen to widescreen HD.
    I wonder if the flickering outline problem could be fixed if I were to use a thicker outline?
    Post edited by EightiesIsEnough on
    edited December 2017
    What rendering engine did you use? If 3DL, try go to the rendering settings tab and increase the pixel samples to atleast 4X4 and/or decrease the shadow rate to 0.5 or less. If you used IRay I'm afraid I can't help since not familiar with that engine.
    Post edited by Sven Dullah on
    What resolution do you render at? 720P it looks like. Render at 4K and it will take longer but pwTon render quick anyway. If you have Adobe Premiere or a similar video processor for effects then you should antialias the final rendered video file and it will remember the pixelation / alias artifacts.
