Lorenzo/Loretta Lowrez bundle -- Loretta's a no-show
dylyn.prosserdylyn.prosser Posts: 0
I bought this recently to make some crowd shots. I can find Lorenzo just fine in the Poser library, but I can't find Loretta there. Where is she?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Should be \Runtime\Libraries\Character\P3DA_LorettaLorez\!!LorettaLorez.cr2 according to the file list - if you use DS, did you install both installers or only the DS one? You need both as the DS one adds only material settings for the figure.
  • dylyn.prosserdylyn.prosser Posts: 0
    I installed it via the download manager. I just checked the product library for it. It says there are three files, but I only see two listed on the "Installed" tab (Loretta Lorez PS & StudioCF). I'll try downloading the other one manually.
    Downloading the third file manually and installing it fixed it. Thanks.
    That sounds as if there's stuff missing from the DIM version - please report that, via a bug report or a support ticket, so that it can be fixed.
  • JaderailJaderail Posts: 0
    I'm not seeing this. I have a 100% DIM install for DS4.5 and I have all the Lorenzo/Loretta Bundle installed. I did nothing other than use DIM.
