Joequick's Street Master Chi disappearing midriff!!
When I use the 'Street Master Chi ', it makes the mid section of the figure invisible. I can't figure out how to undo this. It's nothing I can see in the surface tab or the 'eye' button on the scene tab, or in parameters. It happen when you conform the jumpsuit. Anyone used this item and figured out how to get back the mid section! Thanks.
  • It's probably set up as a GeoGraft to hide the areas that might poke-through the outfit. You can use the Geometry Editor tool to cnage the AutoHide group, though you can't completely eliminate it (without editing the files by hand).
    Select the base figure (Genesis 2 Male), with the clothes still fitted (but hide them so you can see what you are doing)
    1. Tools>Geometry Editor
    2. Click on a bit of the figure that will be covered by th clothing - a single polygon will do
    3. right-click in the Viewport, Geometry Assignement>Assign to AutoHide group for fitted item (I think, going from memory here)
    4. select the Street Master outfit in the dialogue box
    5. Use the tools menu to switch back to whatever you usually use
    6. Fit the Street master clothing to None, then back to Genesis 2 Male.
  • rorsdorsrorsdors Posts: 51
    edited November 2017
    Thanks for replying, I'll give that a go. yes
    Post edited by rorsdors on
