Trouble finding Genesis Essentials in Poser Pro 2012
neterneter Posts: 0
Hello Daz Community!
I've got a problem I hope somebody can help with. I have both Daz 4.5 & Poser Pro 2012 installed. I've already installed Dson into Poser which does appear in Poser. I've also installed both Genesis Essentials files into Poser but it does not appear in the Poser library. Am I missing a step somewhere? The Genesis default recommendations were not the same for the Daz version & the Poser version. The first time I believe I had to do a custom installation, as Poser Pro 2012 did not appear as a path option in default.
Since I could not find it in the library in re-installed them both. The Daz files then showed both Daz path & the Poser Pro path. The Poser version however only showed the Poser Pro path. After re-installation Genesis Essentials is still not showing in the library, any body with a solution would be greatly apprieciated. Both Daz 4.0 & daz 4.5 and Poser Pro 2012 all appear in both Daz & Poser in the content directory formats.
  • Richard HaseltineRichard Haseltine Posts: 111,949
    You need to have both the folder you install the Poser Companion files to and the folder you install the DAZ Studio files available to Poser - I would simply install the Poser CFs to your DAZ Studio content directory, and then click the folder icon with a + at the top of the Poser library pane and select that folder as an external library for Poser.
