Background "none" color - how to change it? Solved !
nowefgnowefg Posts: 557
edited November 2017 in The Commons
I used some product or other that changed the color of the "none" background in the environment tab.
It used to be gray, now it's black, and makes it hard to see what I'm doing.
I looked around the UI, including preferences, but couldn't see a way to change that default color when the backgound is disabled.
How?
Post edited by nowefg on
  • nonesuch00nonesuch00 Posts: 18,897
    There should be in the top right if you have default DAZ Studio layout below the Scene tab another tab called Environment. You turn on and off the background image & change background color & whther or not to use them there.
  • nowefgnowefg Posts: 557
    Thanks, nonesuch00,
    I'm not trying to change the "background" color.
    When I select, "none," instead of "background," the dropdown option to change color disappears. It's the color of that "none" is what I want to change.
    What am I missing?
  • FistyFisty Posts: 3,416
    Window->Style->Customize Style
    485 x 432 - 15K
    Post edited by Fisty on
    Thank you, Fisty!
    Oh, glad you are sorted.
    No problem smiley
