can i apply dforce cloth on previous clothing?
hi. can i use the new daz dforce on pass clothings. or how i can i apply it to a newly created cloth or outfit in daz from marvelous designer or zbrush? thanks
  • TheKDTheKD Posts: 2,711
    edited November 2017
    Yes, some wont work without weight mapping it though. From MD it works ok so far, but MD does draping better, so I usually drape in there when I make clothes. Zbrush, it should work, if the mesh is welded properly.
    Post edited by TheKD on
    awesome thanks. will try it out
  • Older clothing takes a bit more preparation to use with dForce, and some just will not work.
    You can do some modification with Daz' geometry editor, but I don't think you can weld vertices. Maybe if you export it.
