Please i've problem with serial number for daz studio 4.5 , it still run in STANDARD MODE
I bought daz 3d 4.5 free , then i download the software
but the first time i run the program it show me a long xxx-xxx-xx-xx--xx like serial, so i've click ok
...further i noticed that daz studio was in STANDARD MODE
so i checked in my account , my serial number i copied my serial and pasted on the field text and NOthing happened, daz was still run in standard mode
so i've unistalled and installed again and tried again and nothing
DAZ STUDO STILL RUN ON STANDARD MODE
  • Scott LivingstonScott Livingston Posts: 4,352
    Did you order DAZ Studio in the store? When you go here: https://www.daz3d.com/downloadable/customer/serialnumbers/ does it show you a serial number for "DAZ Studio 4.5 Pro?" Try copying and pasting it again...or else try just typing it in (maybe when you copied it you grabbed an extra space character, or you were missing a character?).
    If all else fails, you could try ordering the software again...if it gives you a new serial number, use that one. If that still doesn't work, I would recommend contacting customer support: http://www.daz3d.com/help/help-contact-us
  • edited December 1969
    YES Thanks ii've found the problem , i bought 3 instance of daz studio so then i copied the third SErial not the one on the top so it doesen't recognised the serial
    now i've fixed but i ve another problem
    i installed GENESIS EVOLUTION MORPH bundle.... but when i load a genesise defautl figure and i check for the morph it doesen't show me all the morph i don't know why
    i've installed genesis evlution body and head on
    document/DAZ3d/my library
    but iv'e noticed that into my library folder there is another folder called DATA and inside there is another DAZ 3d floder and inside therare many folders included another Genesis folder and BASE folde rinside... the morph have been installe into this folder (BASE) .... its the right place?
  • TotteTotte Posts: 15,110
    Yupp, morphs for Genesis goes there.
    If you select Genesis and go to the Shaping Tab, go you see then there under Actor or Head?
  • Richard HaseltineRichard Haseltine Posts: 111,367
    Yes, the Data folder holds the actual data while the people folder holds the files that tell DS to load it, and local settings such as poses. In this case if the morphs are installed and in the \Data folder they should be loaded with Genesis ready for use.
    sorry what is it genesis ready for use???
    The morphs should be loaded with the Genesis figure, and ready for use in DAZ Studio, does that help?
    When you load Genesis into your scene, it already has all the morph dials ready to use in the Parameters, Shaping, and Posing panes. There's nothing in the Content Library you need to click on to activate them.
