Age of Armour Athmospehere Cameras with DAZ Studio 4.10?
nikolaj.alasdair
...next question...
The Age of Armour Athmospehere Cameras should work with DAZ Studio 4.10 but it seems impossible to install and find them... what am i doing wrong?
I believe there are some small shader/support scripts that need to be installed in the DAZ Studio program folder (with the application), in addition to the normal elements that you see in the usual content library.
If you use DIM to install, try and remove the cameras package and then install it again.
If you don't use DIM, the zip installer file should have two folders, a 'Content' folder and a Prog... folder (i forget exact name). You'll need to manually copy the contents of the Prog folder into your local DS Program installations (both 32 and 64 bit, if you use both, and in both the normal and beta versions if you run beta versions - up to four locations...)
I hope this is relevant to your problem/package and helps,
--ms
