Iray Preview Render (IPR) in viewport - how to change the settings?
Hi,
I'm using Iray render in my viewport set to full-screen (Shift F11). It renders faster than the full-blown render, but it will always stop before the image is complete. I have already set the Max Samples to 10000, turned off Render Quality in the Render Settings, and Render Time to 0. The Iray preview in viewport does not seem to obey these settings. Does it use a different set of settings, and if so, how do I change them?
This is easy just go to the Draw Settings Pane, change Draw Settings to NVIDIA iRay, then seach for the Property Draw Mode and change it to Blend Photoreal to Render Settings. Now the render settings should affect the iRay Preview in the Viewport. At least it sounds like it should.
