clean meshes
laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
Hi!!! I have different meshes, imported from zbrush, and , well, not corrupted, but,... complicated... so, save is long, and unsafe... is there in C8pro some Tools, to clean meshes???
    edited April 2013
    not sure with carrara ?
    try
    http://meshlab.sourceforge.net/
    Post edited by Headwax on
  • 3DAGE3DAGE Posts: 3,321
    HI Celmar :)
    You should have options and tools within Z-brush to reduce the exported mesh (poly-count)
    Carrara has a "Decimator" in the vertex modeller,.. to reduce mesh,. but the issue is being generated in Z-Brush, ( by exporting a high poly model) then importing that into Carrara,.. you'll get serious slow-downs.
    the answer isn't,,. "Fix this in Carrara",. it's,,. "Fix it in Z-brush" by reducing the definition of the High polygon surface you've created in Z-brush,
    Export a Displacement or Normal map from your High definition model in Z-brush,. then reduce the models definition and export,..
    In your 3D program,.. load the low / medium poly model,. then apply the high detail Displacement or Normal maps to make the lower poly model lok like the High poly model.
    Hope it helps :)
