Not sure if this is correct for questions on errors in log file.
cismic
I've been seeing tons of these types of errors and they do slow down a render. Received update to 01254 iterations after 10113.594s.
- 2017-11-21 06:53:38.838 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.0 IRAY rend error: Degraining filter cannot be combined with "black pixel filter".
- 2017-11-21 06:53:38.843 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00005 iterations after 0.170s.
And, I've noticed that on a super minimal render seems like iray is not releasing memory. Causes crashes
- 2017-11-21 11:30:27.510 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 0: cannot get memory statistics (out of memory)
This is an unusual error as I monitor folder creation and I don't have this folder on my machine.
- 2017-11-19 23:03:56.814 WARNING: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdk\include\dzbufferobject.h(121): Error generating GL Buffer Object: invalid value
I'm not sure if this 10054 means that the task can't write to my local db or what and if it's ok to ignor this "warning"
- 2017-11-19 23:02:42.856 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
Thanks all please let me know where to file these bugs or if they are known.
Joseph
Sorry to necro this post, but I just noticed the same error:
Not sure where it's coming from. Anyone got any info?
Searching for "HUDSON_HOME" gave two pages of results, starting from 10 years ago, this one was the only one "solved"
https://www.daz3d.com/forums/discussion/comment/840050/#Comment_840050
Thank you! I'll look into that one and see if I can resolve the issue.
