Skin Doctor 3 Wet and Wild won't install
Skin Doctor 3 Wet and Wild is throwing the following error:
The "IM00048435-01_SkinDoctorWetWildforGenesis8and3Females.zip" file is invalid. It does not contain a manifest, or is corrupt. The product cannot be installed.
I have redownloaded the product with the same error. Other products install perfectly.  Is there a fix or is this known and awaiting a fix?
Thanks,
Scott
    What method are you using to download?
    It is usually best to clear the browser cache if you have a fialed download before you attempt to download again.  If the dowload has corrupted then further attempts to download can stall at the same point.
  • SimonJMSimonJM Posts: 6,100
    Same here, using DIM - deleted package and re-downlaoded with same result.
    edited November 2017
    OK   we can report if it is confirmed,   thanks Simon.   Didn't want to wake the guys up if it was just a possible corrupted download.
    Post edited by Chohole on
  • TomDowdTomDowd Posts: 200
    i can verify as well - same issue. Also cleared, deleted, re-downloaded, same result.
  • wsgentrywsgentry Posts: 573
    I used DIM. It downloaded and installed properly today.  Looks like it was fixed.  :)   Thanks!
    Scott
