Can't find Genesis 3
I'm new to this, and I downloaded Daz Install Manager with everything except that Photoshop bridge thing. I have only been able to find genesis 3 for male as actor, but no female. I only have the basic female, fairy genesis and genesis. I can't even find genesis 2 for male or female.
Also, if I were to purchase an actor that has required products listed, like Kala for Aiko 6 ( random example ) would I have to purchase Aiko 6 in order to use it? Sometimes there are more than two required products. And if in that case, would I have to purchase both?
Do the base figures appear in the Content Library pane under Daz Studio Formats>My Daz 3D Library>People>Geensis whichever? (Where My Daz 3D Library is the folder you installed to.) If so it's just a database issue - for some reason, such as closing DS and then immediately starting DIM so that the CMS ended up shut down, the products were not entered into the database but the files are there - uninstalling and reinstalling should fix this.
Whether you need the iconic character depend on the add on - if it says it uses the base UVs then it should apply, though without the iconic figure the shape will be different.
