Difference Between Victoria 7 and Victoria 8
Hey,
I'm wondering what's the difference between these models, not only Victoria but the new "8" models, how they are different from 7? Do they have a higher polygon count? Are they using the same rig? I am wondering which one to buy now.
  • BeeMKayBeeMKay Posts: 7,019
    8 has lower poly count, different base pose, slightly different rigging, and some other features. Both have limited downward compaibility as fas as skin is concerned.
    Some say that 8 bends better than 7.
    Thanks for the reply, I will get the 8, I heard their default pose is not a T pose, but A pose.
  • vwranglervwrangler Posts: 5,045
    Before you get Victoria 8, you need to make sure that you have downloaded and installed the Genesis 8 Starter Essentials. Those will be in your account in your Product Library; the link should take you to them.
    I wanted to emphasize that because the starter essentials should have answered your question about the default pose, so I wasn't sure you'd downloaded those. Without that, Victoria 8 won't work.
