Daz3D closes on startup (after "building interface")
Hello all,
I've tried my best to troubleshoot this on my own by looking at similar threads with no luck, so I'm hoping someone will know what's up. Ever since the update to Daz3D 4.10 I haven't been able to start the program. It was working fine before this.
I've tried:
- Uninstalling/Reinstalling through DIM
- Uninstalling/Reinstalling through the Daz3D package on the site
- Setting Daz3D to use my 1070 in the Nvidia Control Panel
- Installing related runtime packages from Microsoft
I'm running Windows 7 64-bit with a 3570k, 16GB of RAM, with a 1070. My drivers are up to date.
I'm not sure this warning is relevant, but in my log.txt file when I try to start Daz3D, it says:
2017-11-17 16:31:00.831 WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
Any assistance would be appreciated!
Is PostgreSQL installed? What security software are you running?
Hi Richard,
Thanks for the reply! Yes, PostgreSQL version 9.3.4.3 is installed, which was installed with Daz3D. Also, I don't use any kind of anti-virus/security suite software.
The other possibility is if you had ever used the right-click, Run as Administrator command on DS or DIM - doing that can cause permission issues, though I'd expect those to fall short of a crash.
