Genesis 3 eye reflections
Choppski
in The Commons
Any thoughts about how to get good eye reflections in 3delight with genesis 3. I am having no luck. With the old M4/V4 I knew what to do--adjust specular/glossiness on eye surface. Even textures like Elijah and Michael & and the other main daz textures don't render with that glossy, wet look to the eye. I can add light or highlights in photoshop, but I keep thinking there must be a way to add the glossiness and reflection.
You want to use the EyeMoisture surface.
Ok, but how? when I try it ends up either white or black.
Turn Multiply Specular Through Opacity off if it's on, then adjust the same way you adjusted the specular and glossiness in M4 and V4.
I'd also use cornea bulge morph too
