Script For Play Image Series (Sequence) or movie
Script for Play Sequence Images or Video with One click or automatically
Script DAZ Studio 3.xx or 4.xx, with MPV(mplayer), play Sequence images or video.
- Play real rate 15, 30 or 60 fps.
- Play Audio External (default wav DAZ Studio).
- Loop Infinite
- A-B loop points
- Control Velocity
- Range Preview (settings of movie DAZ)
- Play Mix different image sizes
- Play automatically after rendering in 4.8.
Requeriments:
Script DAZ Studio
mpv (mplayer)
https://mpv.srsfckn.biz/ <---- For Windows
// DAZ Studio version 3.1 filetype DAZ ScriptMpv = '"C:/Program Files/MPV/mpv.exe"'var oRenderMgr = App.getRenderMgr();var settings = oRenderMgr.getRenderOptions(); var FileNameAudiovar tick = Scene.getTimeStep();var fps = Math.round( 4800 / tick );var TimeRange=Scene.getPlayRange();//Make Movieif (settings.isCurrentFrameRender==0){ RangeTimeMovie=DzTimeRange(settings.getStartTime,settings.getEndTime ) FrameA = RangeTimeMovie.start/tick FrameB = RangeTimeMovie.end/tick Startss = FrameA / fps Endss = FrameB / fps if(settings.renderMovToId==0) { FileName = settings.renderMovFilename PFileVideo = ' --no-correct-pts --fps=' + fps + ' "' + FileName + '" ' } else if(settings.renderMovToId==1) { var regexp1 = /(\.)(.{1,3})$/; FileName = settings.renderSerFilename FileName = FileName.replace(regexp1,"*$1$2") PFileVideo = ' --mf-fps=' + fps + ' "mf://' + FileName + '" ' } if (Scene.getAudio()) { PAudioFile = ' --audio-file="' + Scene.getAudio().filename + '" ' } else { PAudioFile = "" } OSD='--osd-level=3 --osd-msg3="Time: ${playback-time/full} - Frame/Total: ${estimated-frame-number}/${estimated-frame-count}"' Arg = OSD + PAudioFile + ' -start ' + Startss + ' --ab-loop-a=' + Startss + ' --ab-loop-b=' + Endss + ' --loop ' + PFileVideo Command = Mpv + " " + Arg debug(Command) new DzProcess(Command).start();}Certain parameters do not work with all versions of mplayer, I only work well with mpv.exe. Tested mpv.exe 0.25.0-92-gbc3365b16
Usage:
In DAZ Studio, set Sequence files images or video and Render your scene.
Run Script ACDZ_Mpv.dsa
TIPS:
- For Play automatically in DAZ Studio 4.8.
Put "Render Settings-Editor-General-Misc-Browse File - ACDZ_Mpv.dsa"
When you finish rendering a range of frames, the player will be automatically executed.
- For Load Script Start DAZ Studio
Save Preset Setting (MySettingRenderMpv.duf) and Set Preferences - startup Launch
Tips MPV-mplayer Keyboard Control
- [ and ], Decrease/increase current playback speed by 10%.
- { and } Halve/double current playback speed.
- BACKSPACE Reset playback speed to normal.
- p / SPACE Pause (pressing again unpauses).
- . Step forward. Pressing once will pause, every consecutive press will play one frame and then go into pause mode again.
- , Step backward. Pressing once will pause, every consecutive press will play one frame in reverse and then go into pause mode again.
- O Toggle OSD states between normal and playback time/duration
- l Set/clear A-B loop points. See ab-loop command for details
- L Toggle infinite looping.
1331 x 522 - 189K
416 x 535 - 44K
358 x 285 - 11K
Post edited by ajd_at_072df9a27d on
Thanks! This is great, liking immediate playback of image series ;-)
