Cloths are to big
BarricBarric Posts: 24
When I send the cloths that I have made from Hexagon to Daz, they look good on the model but when I use the transfer utility the cloths expand. I have tried everything I could think of to make them fit properly.
  • SzarkSzark Posts: 10,634
    Did you model the clothing on a Morphed figure insteaad of the base figure shape without morphs?
  • BarricBarric Posts: 24
    I have done it on both morphed and non morphed. First time was on a morphed figure. Second on a regular Genesis figure.
  • Richard HaseltineRichard Haseltine Posts: 111,688
    Do the clothes fit on the zeroed figure, or do you have to adjust them? The Transfer Utility works on the zeroed state of the OBJ and of Genesis, though if you've modelled around a morph you can get round it by selecting Morph and then the morph you used under Source shape, or by selecting Current, and then expanding the More options button and checking Reverse Source Shape from target.
    I have discovered what "I" did wrong. I made the shirt with a morphed model. When it didn't work I used the same shirt on a regular model.
    I had spent about 6 hrs working on this shirt and didn't want to start from scratch. Now I know. Every thing is working fine . I made a quick shirt from scratch on a regular model and it fits.
    Thank you all for you help and advice.
