Useful Mirrors
I know this has probably been asked before, but it is such a while since i used it i have forgotten, and i can not find it anywhere in the forum
How do i use the Useful mirror shader to apply to Genesis 3 or even the basic female, could i use it on any leter genesis figures, beleive me i have tried and just getting nowhere
thanks
pete
  • LeanaLeana Posts: 13,486
    You mean this product? https://www.daz3d.com/useful-mirrors-for-daz-studio
    To apply the shader to a figure, select the figure and all the surfaces you want to apply it to, and then use the shader preset.
    Just remember this is a 3DL shader and won't give good results in Iray (as noted on product pasge).
    Yes, and tried that just doesn't want to work on any figure
    pete
    Whar problem are you having when you try to apply it?
  • vwranglervwrangler Posts: 5,042
    edited November 2017
    If you're trying to apply the Useful Mirrors shader to surfaces on Genesis 2/3/8, that likely won't work at all. Useful Mirrors is old enough that its presets, according to the File List in the readme, are all .DAZ or .DSA files. The only presets that will work on Genesis 2/3/8 are .DUF files. (I suspect, if you're using Smart Content, you can't see the file extensions, which may make things even more confusing. I don't use Smart Content, so I'm not sure about that.)
    And, as noted above, it won't work in Iray at all.
    Post edited by vwrangler on
  • petes imagespetes images Posts: 213
    thanks for that i accept they won't work, however since this post I have tried the iray shaders on other surfaces, they won't work iether
    pete
    Post edited by petes images on
  • Okay, I'll bite.... IS there a way to apply mirror shaders onto Genesis1/2/3/8 characters and have them work?  Say, one of the iRay mirror shaders?
    pete
    Found this on yu tube which ultimately leads to other tutorials Daz Studio Tutorials Introduction part 1 of 16
    pete
    Found this on yu tube which ultimately leads to other tutorials Daz Studio Tutorials Introduction part 1 of 16 so working ok (except the original Useful Mirror shader)
    thanks
