Looking for druse/druzy model
I'm looking for a druse/druy model like the one in the image. Does anyone know where I can find one?
  • BeeMKayBeeMKay Posts: 7,019
    Thanks... the turbosquid models aren't quite what I'm looking for, unfortunately.
    Looks like I'll have to go the custom model way.
    knowing what a colleugue  paid fo a realtively smaal one of those I do wonder how much that display of amethyst is valued at.
    edited November 2017
    Good question... the image is from the site of a swuiss trader: https://www.hde.ch/contents/de-ch/d769_amethystdruse.html
    Post edited by BeeMKay on
    Ye dogs.   I would think twice about buying even one
  • Charlie JudgeCharlie Judge Posts: 13,629
    I  bought a medium sized one for $200usd quit a few years ago when theose Brazilian lava tube geodes first came on the market. Even then some of the larger cathedrals were $400 - $500.
    Post edited by Charlie Judge on
  • JOdelJOdel Posts: 6,322
    You might end up having to kitbash it for the geometry, and apply a shader for the amethyst. I know I've seen plenty of crystals in various stores (here and Rendo, mostly), Usually as parts of larger sets. They can be scaled down, or the crystal portion separated out with the geometry editor and scaled down. Finding a hollow rock, or something to use as a hollow rock, might be a bit tricky, but since the crystals are inside, it shouldn't matter too much if they intersect each other. (Depending on how close you intend to render it.)
    I wonder if high displacement on a noise texture map could simulate the crystals? People used to do displacement fur, which at least did appear to be a texture with dimension.
    Post edited by JOdel on
    Yes, the hollow rock is the tricky part... but I thought I can perhaps kitbash the rock, too. I'll have to experiment and see. smiley
    The noise texture might work for smaller crystals, but if I want the sparkle, I'll need proper structure.
  • srieschsriesch Posts: 4,243
    If you were doing an extreme closeup were you can't see more than just the very lip of the outside edges or viewing from the inside out, you might be able to use https://www.daz3d.com/tropical-cave as a hollow rock, with the camera positioned just above the main opening.  And of course if you were completely inside the geode you could use the inside of any rock.
    There is a half geode in this set https://www.renderosity.com/mod/bcs/crystal-valley/107929/ , and although the crystals are very large you could always hide them and then line the interior with your own smaller crystals from elsewhere.
    Perhaps you could also take something like a bowl, pot, or glass and deform it into the desired partly-open geode shape.
    A displacement map that has crystal points would be super handy, however given that it would be deformed when mapped to random hollow objects it would be a little tricky.  It might still work if tiled though, especially if the crystals would be slightly randomized in size and shape anyway.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,521
    LAMH painted on and brushed inside a rock prop with a hole cut out with the geometry editor and one of the crystals from the various DAZ sets as  instanced geometry
  • LinwellyLinwelly Posts: 6,070
    Might be you could populate a cave with crystals by using ultrascatter
  • I created this over the weekend, pretty rough but if you're interested I'll tidy it up a bit and work out how to package it for sharing
    1000 x 1100 - 133K
    It looks great. I'd be interested in it. Thanks.
    Very nice work!
    Very nice, and definitely interested.
    I plan to use it in my webcomic, is commercial use covered in your license for this?
  • Ever been inside of a geode?  It's amazing.
  • I only have a tiny little piece of one with Amethyst crystals on it, never actually seen one ( full one)  in real life crying
    1600 x 1200 - 119K
    They are totally stunning.  A colleague bought one, back when I was still working.  Like you I only a have a small bit of one ;- similar to this Amethyst
  • Extremely new to Daz Studio, so having a hard time working out how to package the files for sharing. It's created from multiple imported .obj files with custom textures and shaders, but I've also done some corrective scaling using a group in Daz Studio... I may have to re-import as a single object and save it that way. Things seem to operate a bit differently in daz than I'm used to; anyone have links to decent tutorials on prop export/packaging?
  • I prefer sliced agates, as they make great map anchors for tabletop gaming.  Some even have a hole in the middle with druzy edges.  Would probably need a similar process to model them.
    Aye,  I had one of those as well, large enough to be used as a table mat.  Unfortunately between the cats and moving it got broken into 2 halves
  • wizwiz Posts: 1,100
    I've never called geodes "druse". The term ("druse" = bumps, "drusy" = bumpy) generally refers to crystals so small that they sparkle and shimmer without really showing crystal shapes, i.e. 1mm cystals seen from 200-300mm.
    Like this pair of earrings.
    Post edited by wiz on
