Cyclopane (Cyclorama?) in DS4
BendinggrassBendinggrass Posts: 1,390
I know Cyclopane (Cyclorama?) is present in DS3 because I used it....... I thing..... so long ago.
But is it present in DS4?
Because I haven't been able to find it.
Or do I have to buy something to put it in DS4?
Thanks.
    The MPC was originally part of the DS included content starting in the late beta stage up through DS3. When DS4 was released, the Cyclorama was dropped in favor of the current props.
    If you don't have DS3 installed, you may have to install it to install the included content. Once you do, you should be able to move or map the content to your current version of DS.
    If you have it in your order history, you should be able to download the last release version.
    If you are a PC member, you can purchase it for the PC price.
  • Richard HaseltineRichard Haseltine Posts: 111,677
    Are you sure? My recollection is that the Faerie Forest content used a "light" version of the Millennium Environment, though I think the beach scene that came after used a light version of the MPC. I can't remember what we had before the Faerie Forest, if there was a before.
  • BejaymacBejaymac Posts: 2,009
    The faerie forest was the free content for DS1, you needed it if you were using the manual to learn DS (yes folks DS1 really did have a manual :P), as the tutorials in the manual used that content.
    Can't remember if DS3 started off with V4 EZ and the beach scene or if that appeared towards the end of DS2's life, it changed to V4 QS and the beach scene half way through DS3's life.
    Alpha and early beta had the High Fantasy clothing, WR playset and MilDragon LE. It went to the Egyptian content that used the MPC and finally went to Fairy Forest around beta version 0.9x. DS3 changed at some point to V4 QS and the beach scene that also used the MPC.
  • robkelkrobkelk Posts: 3,259
    I came in mid-way through DS3's lifespan. I remember getting the Cyclorama as part of the Safari Starter bundle, which was free at the time - it wasn't part of the default DS3 install (or, if it was, I over-wrote it with the full MPC early on).
  • WildlyfeWildlyfe Posts: 93
    I could have sworn it was in the first DS4 content bundle.
  • IvyIvy Posts: 7,165
    this is a great background prop I use it all the time and and it works great in all verysions of DS and poser and you can buy it here
    http://www.daz3d.com/multiplane-cyclorama
    PS also once you buy it there are a ton of free textuies provided for it on sharectg.com by Hobo
    http://www.sharecg.com/pf/full_uploads.php?pf_user_name=hobobo
    It's possible DAZ used the DS3 content in the very early beta releases of DS4. When the actual release of DS4 in the 3 for pay versions of the planned 5 versions (Standard was free because the free web and lite versions were not available at the time, Advanced and Pro) occurred, they had the current included content.
