Is there a way to transfer a single morph from Genesis into a clothing item?
3dOutlaw3dOutlaw Posts: 2,481
I've had good success with the Transfer Utility, and keeping the morphs for clothes, fit to Genesis/V4 shape. (using this)
...but, there is a morph or two in Genesis that I would like to "add" into the clothing after I get it fit using the above. Is there a way to do that? (or another tutorial, or something?)
For example, if I wanted to transfer the Genesis Pregnant morph into a shirt.
Thanks!
  • BejaymacBejaymac Posts: 2,002
    Conform the shirt to genesis, dial up the morph in genesis, the (crap) auto generated morph system will add the morph to the clothing, you can then select the shirt and use "File > Save as > Support asset > morph asset" to save that morph to the clothings data folder.
