AoA skin shaders occasionally rendering white
Hello...
Very occasionally, when using AoA skin shaders on some characters, they'll render white in both preview and actual rendering, as though 3Delight doesn't "see" the shader. There's no way to kknow when it may happen, and it seems that only closing DAZ and/or rebooting sorts it. I like the shader, but this is very frustrating, and the issue is specific to AoA. Any thoughts would be appreciated!
This is a known issue - if you check ther log, or enable the history in the progress bar, you will probably see a complaint about an invalid interface. You can fix the issue by clearing the AppData(Win) or Application Support (Mac) folder /Daz 3D/Studio4/Temp/Render/Brickyard folder (closing DS or doing File>New clears this out, which is why it fixes the problem).
Thank you!
