Daz3D dose not display installed poses
Hello i have a zip.file of poses for Victoria 7, when i open and drag the file in to the C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads, DazIM dose not found anything to install. So i tried to locate it manually and unzip the files and paste them in to the C:\Users\Public\Documents\My DAZ 3D Library\People\Genesis 3 Female\Poses\Victoria 7\SynfulMindz\Don't be shy Poses. But in the content tab in DAZ3D the poses are missing. However if i drag a single file pose in to the model loaded in DAZ the program load the pose without a problem. Any suggestions ?
Is this a pose set from DAZ, or from another store, or a freebie? DIM can only install .zip archives downloaded from the DAZ store, other content must be installed manually.
You said "the content tab" — which one? There's the Content Library, which shows the actual content files stored on your computer, and Smart Content, which shows a database view of links to your content files. If the installer didn't include the extra files for the database, the content will not appear in Smart Content.
How exactly are the poses missing? Can you see the folder, but it's empty? Or can you not find the folder at all?
Did you copy/paste the files while DAZ|Studio was open? That won't work, the new files won't be detected until you close D|S and re-open it.
If i remember right the file was downloaded from the daz's store that was long time ago. I tried everythig i put the files while daz was closed, i tried even when was the program open. The poses missing in the content library and in the smart contet as well. But as already say if i drag a single pose from the folder outside the program in to DAZ the program load the pose.
EDIT
I just check the content library again and i found them there but the problem with the smart contet stays!
Smart Content requires metadata - manually isntalling won't load that even if the set has the necessary files (check for a Runtime/Support folder in the zip).
