Poser content to Daz3d conversion
So I've got a handful of Poser packages which while they load the objects in Daz3d, they lack dials for modifications.
Examples include a space ships guns, and doors without dials.
Is there a way to create dials for these items?  Is there a how to someone could link me to?
Thanks!
  • SixDsSixDs Posts: 2,384
    Assuming that everything is placed correctly in your content library, the most obvious culprit for losing morph or movement dials/sliders would be the fact that the content is rigged using Poser weight mapping, which differs from DAZ Studio weight mapping and is incompatible. Assuming that that is the case, the only solution would be to manually re-rig the items in DAZ Studio.
  • It may also be that the item uses external morph files - .pmds - which DS supports only for figures.
  • NorthOf45NorthOf45 Posts: 5,896
    Wait, Studio supports PMD's? I thought that myth was busted many times. Where's the definitive answer to that?
  • frank0314frank0314 Posts: 15,098
    edited November 2017
    Where did you buy these packs so we can look them up and see?
    Post edited by frank0314 on
    Right here, though many are no longer available. Almost exclusively RDNA imports.. I'll have to dig a bit, but I've been keeping track of what needs work. So far I've found these:
    28118_The Deadliest Mixer
    28148_OMG It's the Bettys
    25576_EF-Cunning Eagle for V4
    25429_EFJA-Leaping Bear
    25326_EF-M4 FutureCop
    28709_Technophilia-Breathless
    26421_Darcassian
    They were on sale real cheap and I thought I could get something out of them, and I can, just not the morphs. I have been hoping to convert them to .cr2's with Poser, but don't have it. It was one of those "some day" projects...
    There's more I'm sure. I haven't used ALL of my stuff.
    DS supports PMD's which are called from .cr2's, but not from .pz2's
    Hm-m. All use pz2's except Darcassian. Those morphs show up. Oh, well, some day...
    26421_Darcassian
    Darcassian, Technophilia -Breathless, EF-Leaping Bear, and EF-Cunning Eagle are all available through Daz; the others might be as well.
    Oh, they all were available here at some point, and I've got them. The ones no longer available were removed for other reasons. I was just lamenting the inability to fully use them.
