Inner mouth fix morphs - Genesis
SandmanGFXSandmanGFX Posts: 75
Does someone know of any morphs that fix the issue that occurs when dialling "Mouth Width", "Mouth Height" or "Mouth Size" of the Genesis Evolution Head Morphs?
The issue being that the inner mouth doesn't move with the teeth, hence the teeth disappearing inside the inner walls of the mouth.
  • Zev0Zev0 Posts: 7,123
    You can select the upper and lower teeth and move them via X,Y and Z.. I always do this myself. Dont think morphs are really needed when you have full control via the default parameters. Sometimes I even adjust the x-scale to narrow it down.
  • SandmanGFXSandmanGFX Posts: 75
    Oh, that didn't even come to mind! I'll probably create some MCM's for these particular morphs tho. Thanks for the reply!
    Cool. Hope it helps.
