Air vent or air duct props?
Bomber
in The Commons
Anyone know of an air vent prop? You know how in movies people or monsters crawl through the air vents? I'm looking for that kinda thing!
The opening, or the actual inside of the vent shaft?
The inside of the shaft. I see plenty of OBJs of non-hollow airducts, but none that you could turn into a "crawling through the vents" scene
Here is an air duct with crawl space: https://www.daz3d.com/lunar-science-station-air-ducts
This has an obj version and looks like it has a hollow interior: https://www.turbosquid.com/3d-models/vent-ventilation-3d-model/927273
That'd be perfect but I was hoping for something square shaped like in most movies. Example: http://southfloridafilmmaker.com/wp-content/uploads/2012/12/Die-Hard.jpg
Would the one I added to my post above (https://www.daz3d.com/lunar-science-station-air-ducts) work?
It's pretty futuristic. I wanted to do a modern day scene like mission impossible. But thank you so much for all of your help! It seems like a rare prop. I'll probably have to shell out 30 bucks for one of the turbosquid ones.
Actually finally found a cheap and square one that looks decent enough: https://3docean.net/item/ventilation-exhaust-system/5744786
Had to search for "ventilation" and not air duct/air vent.
Maybe this? https://www.daz3d.com/earkham-s-zworld-derelict-locker-room
Check the other ZWorld products. It has a cool ceiling that you can climb inside.
https://www.daz3d.com/earkham-s-zworld-the-hallways
a textured cube primitive or 3 would do in a pinch, load with enough segments to cut out joins using the geometry editor apply a dull metal shader
