Just Curious
Is it possible to actually install DAZ Studio on an external hard drive? When I install it on my internal one, it goes into the Program Files folder, but my external drive doesn't have that. just wonderng if that's possible.
  • Yeah. You have to run the executable yourself though. Once you have the installer launched, there's an option to change the install path.
    I haven't tried this, but if you're using DIM, I think you can go into the settings under the Applications tab and click the little + button at the bottom. Pick DAZ Studio, version 4.5+ and pick a path on your external drive and then install DAZ Studio with DIM. This is assuming you don't already have DAZ Studio installed.
  • fixmypcmikefixmypcmike Posts: 19,731
    Correction:  in DIM, go to the Settings > Installation tab and set the 32-bit and/or 64-bit software paths at the top.  The Applications tab just determines where plugins are installed.
