Saving a material preset without maps
SotoSoto Posts: 1,451
Hi.
Someone knows how to save a material preset that doesn't includes maps info?
I want something that applies only the values without changing maps.
I tried diting the preset file by hand, but I'm getting an error.
Thanks.
  • Richard HaseltineRichard Haseltine Posts: 111,984
    It isn't possible with a .dsa preset, without adding new code. I haven't tried very hard with a .duf preset. Which were you using?
  • SotoSoto Posts: 1,451
    I tried first with duf in a text editor.
    Then I tried with dsa inside DAZ Studio, but both attempts gave me an error message.
  • wancowwancow Posts: 2,708
    Hellboy, is this something you're intending to distribute?
    edited April 2013
    Eventualy, yes.
    But for now I also want to avoid the ctr+double click.
    Post edited by Soto on
    damn, I never really thought about it before... there really is no way to do this... :( Was just trying myself...
  • scorpioscorpio Posts: 8,534
    Just an idea - if you remove the maps and then save as a material preset will that work
  • millighostmillighost Posts: 261
    Hellboy said:
    Hi.
    Thanks.
    You can save it as a "Material Preset". This is like a pose preset, only for material settings. Here is how to remove the diffuse image from it: Open it in your editor and search for the "scene" section. It looks somewhat like this:
    "scene" : {
                    "materials" : [
                                    "url" : "#Default",
                                    "groups" : [ "Default" ]
                    "animations" : [
                                    "url" : "name://@selection#materials/Default:?diffuse/value",
                                    "keys" : [ [ 0, [ 0.9294118, 1, 0.8313725 ] ] ]
                                    "url" : "name://@selection#materials/Default:?diffuse/image_file",
                                    "keys" : [ [ 0, "/C:/users/millighost/My Documents/image/texture/10x10-measure.png" ] ]
    The "animations section contains keys for the various parameters. In the example above, the parameter that contains the image is
    If you remove it (the 4 lines with the curly braces around it (and the "url" and the "keys" in it), this preset file will not overwrite the diffuse image anymore. For other parameters the procedure is the same. One minor detail to remember: if you remove the very last key in the "animations", you also need to remove the comma at the end of the previous key, otherwise it will give an error.
  • vwranglervwrangler Posts: 5,059
    edited April 2013
    EDIT: Never mind. Misread the post before mine.
    Post edited by vwrangler on
