Question regarding strange artefact (Hexagon->Studio)
Hi,
it's been a while, but I recently fired up hexagon to build some simple facing brick tiles. It's basically some cube primitives scaled in x,y and z and offset with minor deviations in translation and rotation. I UV-mapped them also in Hex. I also checked the normals.
When I export those as OBJ und import them into Studio, I get strange shading display in the preview and two tiles also look significantly darker in the rendered image. Any idea what could cause this? I have attached screenshots from Hexagon and Studio...
Any help would be greatly appreciated!
925 x 1024 - 48K
1350 x 1009 - 93K
  • Are they just one polygon per face? You may need to eithre adjust the smoothing angle in Surfaces (or turn smoothing right off) in DS or bevel the edges in Hexagon. By default DS will try to shade the transition to smmoth the trasnition out (that's why the humans and clothes don't look as blocky as they should).
  • Hemi426Hemi426 Posts: 231
    Yes, it's a single polygon per face. Thank you very much for the hint! I'm gonna try that when I get home tonight.
  • MaxHancockMaxHancock Posts: 227
    edited November 2017
    Smoothing should be turned down for hardsurface type of objects.. but even still, it's strange that it's overshading just those two blocks. It could be a problem with the model, but I'd have to take a look at it to know for sure.
    Post edited by MaxHancock on
    Actually turning off smoothing in the surfaces tab did the trick. But I was also surprised that the problem only appeared on two of the primitives (they are all just copies of the first one). I will post pictures tonight (rendered and wireframe).
    Anyway: Thank you!
    Here's a pic of the mesh (not mouch to see though)
    I have also created morphs to straighten the interlocking parts on both sides (in case you need a straight edge). It's uvmapped, but the tiles are spread randomly on the texture to get the random effect.
    Here rendered with a procedural texture:
    And here with a slate image as texture
    899 x 966 - 91K
    1200 x 900 - 2M
    1200 x 900 - 2M
