Genesis 1 male characters are now all female with 4.9 upgrade
All my genesis 1 characters are now female. None of the male morphs have held. Is there any way to reverse this? I am having to redo most of my characters with Genesis 2 and up, but this is a pain since I am also losing textures. Any help will be greatly appreciated.
    thaz a pretty bizarr bug.  have you looked at your log?
    any messages about missing files?
    Can't resist this link, but it will not solve your problem.  Listen to Misty.  yesyes
  • 3Diva3Diva Posts: 12,058
    edited November 2017
    Is it just that the base female morph got saved as the regular Genesis figure? Load one of your guys and scroll down the Shaping Tab and see if you can find the shape morph that is dialled in that is affecting your male characters.
    Post edited by 3Diva on
    tee hee
    my fave line in the movie was like "we're back in the car"
  • That sounds as if a female shape has been saved with a non-zero default value. Load the base Genesis figure, look in the Parameters pane under Currently Used and see if there are any obvious suspects. it's most likely to be a freebie but it could have been done after the fact to a standard morph if the Save Modified Assets command was used.
