DIM minimum system requirements (Mac).
Dan Whiteside
I'm still stuck on OS 10.6.8 cause Bryce Mac is still stuck there (almost 2 years now and counting) but I don't see any Mac system requirements listed for the Install Manager. Does anyone know what they are ?
I'm also using an older version of D{S 4.5 - any minimum requirement there?
Also I see that installers start going away May 15. Does that mean that without DIM you just get the files and one has to place then manually?
Apologizes if this has all come up before...
TIA;
Dan
I can answer the last. Without DIM you get Zip files. not installers.
I've been having a lot of problems with the install manager. It's installing to the default paths but some content isn't found and others are somewhat confusing. I too am running a Mac OS 10.8.3 DAZ 4.5. Help desk have basically told me it's my fault but not explained what I can do to fix this. Does this mean I have to install everything manually?
When I load the files manually they work fine. Is this my only option?
Appreciate the info. Thanks!
