Tithe Barn and Castle Window for Iray please
Hi,
A question for SoulessEmpathy: is it possible to make these buildings and interiours for Iray? Or is there a way to make them work in Iray?
Thanks.
  • FSMCDesignsFSMCDesigns Posts: 12,859
     Nearly everything works in Iray. You might have to adjust a few parameters in the materials pane like reduce specular, but looking at the product I see no reason it wouldn't work. Skin is the complicated one, but props are very easy to fix between renderers.
  • Thanks for your reaction. But I can't get it working. I've placed some new lights and also a HDRI for the light coming through the window. But everything stays dark. What parameters exactly do you mean? Is there a prescription for converting 3Delight to Iray?
    Thanks.
  • FenixPhoenixFenixPhoenix Posts: 3,259
    Thanks.
    You can always select the glass, then go into the surface paramenter and replace it with an iray glass shader. If the glass has surface that you wish to maintain, just right-click the glass shader and have it not replace textures.
