Not seeing Dforce Tab or add Dforce modifiers in Edit-Object-Geometry tabs
I just upgraded to 4.10.0.107 via DIM but I am not seeing the Dforce tab available in the panes / tabs list or in the object figure edit menu.
Anyone else have this problem?
Thanks
  • Is Update and merge menus available in Window->Workspace? If so, use that to add the stuff that is missing from the menu system.
  • Thanks. That gives me the add dforce modifiers options - but is there supposed to be a Dforce tab as well?
    There is an associated pane, but it's called Simulation Settings.
  • The tab should be called"Simulation Settings".
    Is there some way to make this persistent? Right now I have to do this everytime I load Daz - this is on a Mac running 10.11.6
    thanks
    I find that I'm losing the dforce tab constantly under objects. I've merged settings constantly, but it doesn't stick. I've just started using the one in the simulation settings hamburger (line) menu
  • TotteTotte Posts: 15,144
    edited November 2017
    thanks
    Quit DS before you run a simulation that accidently causes it to crash. It saves this upon quit.
    Then restart DS, it should be there now.
    Post edited by Totte on
