DemonicaEvilius
Do you have a contact address? Can you breifly explain how you (seemingly) work in callaboration with another artist such as Silver? I'm interested in your face paint stuff. Thanks
  • frank0314frank0314 Posts: 15,098
    you would need to contact the individual vendor to see if they wish to work with you. You should have references available for them to look at to help them with their decision. If you go to your PM inbox and compose a new message just start to type in the recipient and the name should come up. Just select from the list. I just tried it and Silver does show up, but you can do that with an member of the forum..
  • DemonicaEviliusDemonicaEvilius Posts: 144
    edited November 2017
    Hiya :)
    Im not quite sure what you are asking so I will answer as best as I can :)
    Basically it started because we are friends and started our PA journeys around the same time. If you are interested in collaborating with PA’s its best to contact them like Frank suggested above!
    It helps to find someone with similar interests/work ethic etc. Also helps if you have complimentary skills to work together, for example; with characters Jess does fabulous character skins/tattoos whereas I mainly like to do the morphs/expressions and stuff like that (we tend to both work in the other stuff like makeups together as they are the most fun parts haha)
    Demonica / Kari
    Post edited by DemonicaEvilius on
