Questions about DIM
Bohn-ReisBohn-Reis Posts: 4
Will I have to use the DIM to install content to my computer or will I be able to use the manual method?
Here's my problem. The computer I use for Graphics (DAZ 3D, Photoshop, etc) does not connect to the Internet; this keeps me from web surfing when I should be working. I download all content to another computer place it on flash drives and move it over. I do connect the Graphics computer to the Internet about once a month for updates but this involves disconnecting some devices and running a separate cable upstairs
Will I still be able to use this same scheme when the switch happens? Will I be forced to use the DIM?
  • frank0314frank0314 Posts: 15,115
    Yes you will be able to do it the same way. You don't have to use DIM if you don't want to but if you do you can download everything to a flash drive and run it through DIM on the other computer.
  • Bohn-ReisBohn-Reis Posts: 4
    Thanks for the fast reply.
    That's a relief as there are conflicting stories traveling around the interwebs.
    Thanks again.
