Daz to Maya problem
Super cheese sandwich
in The Commons
I can't make it work. What I'm doing wrong? I have Maya 2017 and the latest version of Daz. I select the figure and then open the script but nothing happens.
You said you selected the figure. Does that mean you loaded into DS? It needs to be loaded into its T or A position, then you can run the script. Make sure you are not using iRay in your viewport when you run the script. It will still work, but it will take longer and you might not think it's working. Other than that, it's easy peasy.
I have tried with both engines and waited more than five minutes but nothing happens. I have tried with G2, G3, G8 and many props but nothing works. I will send a ticket to see if daz can help me. Thanks for the help anyways
