Can not open genesis 3 models
I have had this issue, ever scence the last Daz update. I am unable to open any Genesis 3 models, when I click on them I get an error that says
Could not open file : People/Genesis 3 Female/Genesis 3 Female.duf File does not exist
When I navigate to this file, it is actually there. I have unistalled daz and reinstalled it, and still nothing... any ideas on how to fix this
437 x 159 - 20K
Where is the People folder? How did you install?
The file is located in /Users/Shared/My DAZ 3D Library
I used Install Manger to install everything
OK, will it load from the Content Library under DAZ Studio Formats>My Daz 3D Library>People>Genesis 3 Female?
When I click on it, daz opens, but nothing shows up
That sounds as if you are clicking on it from the OS file browser with DS closed - I meant going to that location in the Content Library pane of DS.
Oh, when I do it that way, I get the same error.
OK, and the product is isntalled solely through DIM - if you right-click on it in a product view in DS it has no unisntall option, only Install and some others?
I acctually see an option for unistall rather than install
Then DS still sees a Connect isntall and is using that not the DIM fiels. Try seelcting the Unisntall option and see if the DIM fiels then load.
