Does Daz 4.10 Iray not support older Nvidia cards?
I have a Geforce GTX Titan Black with 2880 Cuda cores and 4GB from about 2 years ago. Is that still supported in 4.10? And does dforce run on the CPU or the GPU or both? Thanks
  • BeeMKayBeeMKay Posts: 7,019
    https://www.daz3d.com/forums/discussion/203081/dforce-start-here#latest
    has the instructions regarding dForce (which does run on both GPU and CPU, but needs extra drivers installed) and
    https://www.daz3d.com/forums/discussion/206696/daz-studio-4-10-pro-general-release/p1
    says about GPU:
    The Fermi GPU architecture (compute capability 2.x) has been marked as deprecated and will be removed in the next release (2017.1, to match the requirement inherited from the CUDA toolkit and accompanying driver releases).
    According to the nVidea Website, your card uses Kepler, so it's safe for a few more years. wink
  • glaseyeglaseye Posts: 1,312
    Mt GTX680 (with only 2GB) is supported, that card is about 5+ years old. dForce usually functions with either cpu or gpu, with the latest nVidia drivers for the gpu and opencl 2.0 drivers for the cpu
  • erostewerostew Posts: 240
    Yeah dForce will run on the CPU or GPU or both using OpenCL 1.2. On the CPU you need appropriate OpenCL Drivers and the GPU has to have up-to-date drivers, which will include OpenCL 1.2.
    Iray uses Cuda which is a whole different animal but your card should most certainly be suported.
  • sapatsapat Posts: 1,735
    I only have an NVIDIA GeForce GTX 760 (192 bit) that's 3 yr old and I use Iray every day.  It's slower but it's what i've got to use. We can't all have/afford the big new shiny stuff. frown
  • MartialMartial Posts: 431
    I have GTX 660 and Iray rendering and Dforce works. Just need to update driver for using dforce
