PowerPose became undockable in last week
Hello all -
I just ran into a strange problem - my PowerPose pane has become permanently undockable. I need to drag the tab into another dockable tab group, but I can't drag from the tab at all - only from the title bar. And even then, I can't dock the pane anywhere. I made sure I'm using the right version for my version of DS (4.9.4.117 Pro 64-Bit). It had been fine up until about a week ago, and it is still working fine in the version on my laptop. I didn't change anything that I know of. so I'm not sure what could have happened.
Any help or suggestions would be greatly appreciated! Thanks!
Michael
  • In the option menu for teh pane is there a Make Pane Dockable command (and a Make pane group Dockable)? If so, select it.
  • I guess I should have been more specific when I said I'd tried everything. I am well versed with the options menu, and the "make pane dockable" is already set.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    edited October 2017
    Try setting the pane deliberately to be Undockable, close DS, reopen, and try docking. Another thing to try is right-click in an empty area next to the tabs of an existing pane group and select Add Pane (Tab)>Power Pose (with Power Pose closed).
  • Thank you so much! I wasn't aware of right click>Add Pane option!
    It's a fairly recent addition, that's about teh first time I've remembered it without prompting.
