Generation X2 Can't find where Selected Morphs (With Controller) are located [Solved]
Ghosty12
Hi I need help, while porting over characters from one mode to another I made the mistake of selecting Selected Morphs (with Controller).. The problem I have is that I want to get rid of them but I can't find them, can anyone tell where they are stored please, any help would be greatly appreciated, thank you..
Update: found where they were hiding so all is fixed.. :)
Post edited by Ghosty12 on
For future readers,
I believe the user is referencing the 'hidden' (not user-facing presets) GenX2 outputs which are usually generated in one of your Content Library 'data' directories - something like:
...\data\DAZ 3D\Genesis\Base\Morphs\D3D GenX2\...
where the figure name (Genesis in this case), and the final folders will change, depending on your GenX2 conversion (e.g. V4 or A3 or ...).
Note that GenX2's third tab can be used to disable and enable sets of these morphs, in case you just don't want to see them all of the time.
Should you decide to move or remove these hidden morphs, realize that any presets you or GenX2 has created that use them will no longer work as expected.
clear as mud?
--ms
